I've been receiving several PMs lately from frustrated IntelliCenter users who want to revert back to Firmware Version 1.064.
This is mainly due to unexplained bugs they are experiencing with FW V2.017 and which did not occur when using FW V1.064.
I posted the instructions back in January on the following thread...
www.troublefreepool.com
However, It's not always quick and easy to find I guess, so here is a dedicated thread for this topic.
INSTRUCTIONS TO REVERT BACK TO FW V1.064
1. Press RESET on the Outdoor Control Panel.
2. Once the OCP reboots, press the gears icon in the lower right-hand corner of the screen.
3. In the Options Window, select the Switch Firmware Version.
4. Find Firmware v1.064 and select it.
5. Press the check-mark.
5. (b) Tap the "Back" Arrow.
6. The OCP should then revert back to v1.064.
I hope this is helpful for those experiencing issues with v2.017.
r.
IntelliCenter 2.006 Firmware
Have you rebooted your local panel? I had weird stuff happening with timing of things because apparently the clock was wonky and I didn't realize it. Just make sure to eliminate that. Double check the clock settings. --Jeff Yes - a couple times. I was forced to reboot the panel as when I...
r.
