Hi all, I searched for answers here but found more confusion than answers.
I am wiring all the low voltage connections to my intellicenter using the RS-485 ports. I have an IC60, intelliflo, and an ultra temp heat pump. I connected the IC60 and the intelliflo to the J4 and J5 com ports respectively but now I don’t know where to connect the ultra temp. Instructions say to use J2 for gas heaters, will it also work for my heat pump? The other section of the heat pump manual says to use the RS-458 but I only have two com ports, do I need an expansion pack then?
I also read something about if you use the RS-485 for the ultra temp, then I need a solar sensor?? Or to trick it with a resistor?? The kit only came with air and water sensors and I don’t plan on having solar.
Thanks in advanced!
Thanks in advanced!
