- Jun 11, 2022
- 9
- Plaster
- Hayward Aqua Rite Pro (T-15)
New Intellicenter (firmware 1.064) and Pentair VSP installed this week due to a full pad equipment upgrade. Have pool and spillover spa with shared pump, plus second Pentair VSP for waterfall. Freeze Protect is enabled on all three circuits, and is correctly turning on all pumps and alternating the valves between the pool and spa ever 15 minutes -- all great.
My question is how to configure the RPM for each pump while running in Freeze Protect? It appears to use the default RPM for each circuit while in Freeze Protect, which is too fast in some cases. (For example, Spa circuit has speed of 2800 RPM which is good while in the spa, but also what it runs at when enabled for Freeze Protect which is too much). For the Pool\Spa pump, there is a circuit name "Freeze" with a lower RPM, but it doesn't seem to have any effect? Ideally, I'd like them just to run around 1800 RPM when in freeze protect.
