IntelliCenter Firmware 2.006 Change Log
jimbethesda
679
Austin, TX
Pentair Intellichlor IC-40
Wanted to start a thread with known changes in 2.006. Let’s keep this thread as clean as we can with changes. Other threads can be used for discussions. Please add to this list.
- BUG FIX: Freeze protection now persists even after a power failure
- BUG FIX: IntelliPH now recognizes when the system is in SPA mode and won’t dispense acid
- NEW BUG: You can’t end your daily schedule with a SPA run. If you do, when that schedule ends, instead of turning off, the system continues to run in POOL mode.
- NEW (BUG? NUANCE?): Spillover circuits must be run with pool mode on. Previously you could just run a spillover by itself.
It looks like this needs to be put on hold until a different more stable 2.XXX release is out.
Reactions: jimbethesda
Did this release fix the grouped RPM/GPM reference to a pump? Current function defaults to individual highest.
Update: Seems 2.006 screwed up my pool cover sensing. I've rolled back to 1.064
