IntelliCenter - Circuit Group & Schedule Issue
rangerks
11
Austin TX
I recently changed one of my Circuit Groups to utilize a different speed on the pump, which is setup as a Feature Circuit and having issues with it working in the SCHEDULES.
This is how I have it setup;
Feature Circuit: PUMP SPEED 2000 (name)
Pumps: PUMP SPEED 2000, setup with RMP @ 2000; setup as a circuit under the pumps
Circuit Group: FILTER HIGH, linked to Circuit: PUMP SPEED 2000
When I select FILTER HIGH from the app or control panel itself, it kicks on the PUMP SPEED 2000 circuit with it. Problem I have is, when I add FILTER HIGH to the Schedules, it turns on FILTER HIGH at the correct time, but the PUMP SPEED 2000 circuit doesn't come on with it.
Screen shots of each setup screen attached
Help appreciated!
That definitely doesn't make any sense.
What happens if you remove the 'Filter High' circuit group from the schedule and just use 'Pump Speed 2000' feature circuit in the schedule?
Edit: or you could also try changing the PS 2000 in the circuit group to your Speed 2800 and see what that does.
--Jeff
@rangerks
Kyle, well what the heck? Yea, it should work exactly as you have described and which is shown in your screen captures.
Obviously, something has got discombobulated.
You might try this.
1. Delete the schedule and then create a new schedule and try it again.
2. If 1. above doesn't work, then try deleting the schedule AND deleting the Circuit Group.
Then re-establish both and see what happens.
r.
