Intellicenter assigning valve to more than one circuit.
rozza12
5
Australia
I have a dual body single equipment intellicenter setup.
The bulk of the the heating is provided by the building Plant controlled independent of the intellicenter.
There is a diverter valve that regulates the flow of water into the heat exchanger that I am trying to control with the intellicenter.
I assumed I could simply add the valve to multiple circuits but I can only add it one at the time.
I have looked at some other post but I am not quite sure how to create a group including pool or spa.
I want it to be open when the main pool mode is running or when one other feature circuit is selected.
Alternatively could program it to be closed when spa mode or when spa mode selected or different feature circuit selected.
Thanks
Rozza
There is a lot that the .IntelliCenter cannot do and controlling one actuator with multiple circuits is one of those things.
You can experiment with circuit groups but they also have lots of limitations as you will discover.
Run the latest version 3 firmware to have all the updates available.
