I recently swapped to my old pool and spa lights with intellibrite 5g lights (ouch, $1400)
Anyway I am looking into using the easy touch/screenlogic Como to control the light. I think my easy touch should have come with 4 relays; my installer possibly took two relays when installing since they were not needed at the time (blower and pump are controlled with relays)
Which relay can I buy to control my intellibrights? I have two other pools with a PL4 and PSL4 - maybe I can pull a relay from there?
Guessing process will be something like this (input/corrections appreciated):
- disconnect inside switch that controls pool light inside transformer, cap that hot
- run new power wires from light transformer to easy touch panel high voltage side
- connect to load terminal(s)
- Pull power from blower or pump breaker, maybe new breaker (not sure here) to a new relay
- Connect to Line side
- connect low voltage side of relay to a free function button (relay trigger)
- Configure easy touch (Maybe even via SLConfig app) for intellibrite
