I have a 22k gallon pool, SWG, Fafco solar panels, and intelitouch i5 automation system.
I'm having issues with the solar sensor not controlling the automatic valve which diverts the flow to my roof. In the past, I've had to change out the solor sensor every few years, then the system was up and running again.
This time I've changed out the sensor four times so far, and even swapped out the board with a spare that I've been keeping around for years.
After changing the board, it worked with the 3rd sensor for about a week, then stopped working. The valve is controlled by an Intermatic 24v actuator, which I replaced about 4 years ago, it still works using the toggle switch on the actuator.
I have my "Heat" setting on the control panel set to "solar Pref" and have tried it on "solar" only as well, doesn't seem to make a difference.
Could it be an issue with the board again? I'm just getting frustrated with this already, have been trouble shooting it off and on for over a month now.
