- Jun 23, 2018
- 2
- Plaster
- Pentair Intellichlor IC-40
30 year old pool with upgraded equipment. A couple years ago I had my pump changed out by Leslies pool to a inteliflo VSF the tech set it up to run high speed on the Easytouch panel and low speed in a feature program. I have been continuously chasing my chlorine levels as the SWG only came on when the pool sweep is on and I would have to change that run time as the weather changes up to 5-6 hours in the summer at 100%.
I recently upgraded my heater and figure out from this forum that my schedules were not right. Now I have my SWC on all the time @ 10% for 14 hrs and pool sweep 2.5 hrs chemistry is good. When I set the pump speed to where the SWC comes on it’s 1700 RPM and only 13-14 gpm that seems really low to me. Also it’s a pool spa combo the spa make-up seems slow. One large concern is that when I turn on the spa booster pump my filter pressure goes up dramatically and I get a high pressure warning. I just finished a complete filter break down and cleaned the SWC. Thanks dougo
