Babs,
I installed a Circupool on my 5 year IG pool about a month ago. It was easy peasy. I didn't do the pump at the same time. That's a little harder but shouldn't be a big problem. I've had a lot of questions about my install of the SWG and I've pasted my "lessons learned" below.
I hope this is helpful.
Chris
I'm thrilled with the RJ+. No complaints at all. Install was easy peasy and I wish I had done it a long time ago. It is putting out plenty of FC at 35% power and matches pool math production output predictions very closely. I wondered a little about this because all the manufacturers use the same basic chemistry and catalysts. Here's what did that may help:
- I would suggest you get the maintenance kit. This provides a spool-piece that can be inserted in the pipe while you have the cell out for maintenance. It is also very handy for the PVC work since it's lighter and has no wire coming out. Once you fit it up with the spool piece in you can take it out and replace with the cell. It will fit perfectly. All of the cell manufacturers use unions with unique threads so you can't just make this up yourself with standard PVC pipe fittings. They had a special on the kit that was dirt cheap as an add-on.
- I used the salt test strips. Easiest strip test I've ever used. It's not a color shade test. The strip is graduated and you look for where the distinct yellow color stops on the strip. Also you have a black line that "develops" at the top to be sure the test has had time. After the black line appears the strip reads the exactly the same days later.
- I used Morton's pool salt. A couple of bucks more expensive but it dissolved very quickly. Definitely do this in the shallow end. It's easier to make a couple of sweeps and then it's completely gone. I did vacuum up a couple of very small piles of sand a couple of days later. I guess that's the non-salt remainder of 99.7%.
- The wall unit only has a 6' cord. Make sure you position it close enough to the power for this to work. Not a big problem but if you have to route around a few other things 6' doesn't go too far.
- Don't forget to hook up the bonding wire, I did - had to get the bonding wire and lug connectors at HD.
- I powered mine in the Jandy iAqualink box to a spare relay powered from the pool pump power relay. This way I can make minor adjustments to the run time with my wifi remote. As the cell ages I'll need to adjust the % power at the wall unit but this should be very infrequent. Also it's easy to make sure the SWG is not running in SPA mode. It makes way to much chlorine for the spa.
- I started at 30% on power instead of 50% since the unit has 2x capacity using TFP recommendations. Bumped it up to 35% and it was adjusted to give me very constant FC in just a couple of days.
I think that's all I have. If you have any additional specific questions just let me know. I'm very happy with the choice so far!
Chris
