We are renovating our pool and replacing the current load center and automation with new Pentair 520540 kit, needing advice on correct breakers to install,
Our electrician confirmed current local code requires GFCI breakers on all pool/spa circuits, not sure if this is correct but I’m planning to replace all of the current non-GFI breakers with new GFI breakers, we will be running a VS pump so installing a GFI breaker in the main panel isn’t a good option and planning to run non GFI breaker in the main panel with individual GFI breakers in the subpanel,
Since we are installing a new Pentair 3hp VSF pump for the skimmer filter I saw there are issues with the VS pumps tripping standard GFI breakers so I already ordered a Pentair 20amp GFI breaker for the VSF,
Planning to install standard Siemens GFCI breakers on the remaining circuits in the subpanel,
*Needing to make sure we have enough space in the new panel for all the breakers we need and wanting to get advice on the type/qty breakers we should install based on our equipment requirements:
- 1x VSF 3hp Pentair for skimmer
- 3x single speed 2hp pumps:
1x hayward 2hp for spa jets,
1x hayward 2hp for water features,
1x Pentair 2hp in-floor system,
- 1x spa blower
- 2x white LED lights for pool/spa,
- currently 2x 15amp GFI receptacles installed for convenience outlets, 1 located on the subpanel, 1 located adjacent to the equipment pad,
- We are also installing IC60 SWCG but we were originally planning to install this using the original non-Pentair subpanel and original Jandy automation system, so I already purchased the separate intellichlor power supply and already ordered the IC60 cell, so we did not purchase the easytouch 8 w/internal transformer for the IC60, (I know we will need to mount another box on the wall without the internal transformer but I like the idea of keeping the IC power supply modular/separate from the subpanel for future IC transformer replacement without dismantling the subpanel, and was able to buy the IC power supply and IC60 cell kit online separately for the same cost as the bundled kit, so I decided to pass on buying the bundled kit)
Here are photos of the current breakers and wiring
Thanks in advance for any advice you can share!
- 1x spa blower
