I didn't turn up much using the search function so here it goes......
16 x 32 concrete pool that's getting a new liner. I want to install 2 nicheless lights on the short wall in shallow end since the pool does not have any light right now. So I need 2 return fittings. Questions:
1. How large of a hole?
2. Use Sched 40 pvc pipe?
3. Do I used just hydraulic cement to fill around pipe in wall? If so will it even stick to the pvc??
4. Is there anything I need for a water stop?
I'm not coming up with much on the net. Any advice is appreciated. Thanks.
