Hey there, everyone!
I have a Pentair TR-100 filter for my in ground approx 28k gallon chlorine pool with a popup head system in Arizona. I was chasing what I thought was a leak from the top cap, but yesterday I noticed water is actually bleeding through the wall of the filter. I don't see any cracks or holes, but water is FOR SURE seeping through the wall of the tank, almost like open pores in the fiberglass. The filter was manufactured in late 2015, but Pentair told me no go on the warranty. One pool store showed me a two step paint on epoxy product which they said "may get you a few more years out of it" but then another local shop told me "That thing is going to fail, those epoxy products don't do anything if you have bleeding out the wall of the tank". So my first question is which of these opinions is the most correct? Is this a real deal safety issue that I should not apply bandaids to and just do it the right way and replace the filter?
I priced out a new filter. A local shop has "rebuilt" filters which they warranty for one year. They quoted me $800 installed for the rebuilt, or $1300 for a new unit. I called around and a local supply place has a brand new Pentair TR100 for $730 plus sand. I am pretty handy and am considering tackling it myself with the new unit but don't want to damage any systems or mess up my new tank, blow hundreds of pounds of sand into the pool, burn out the motor, or generally cause any additional mayhem with an already expensive situation.
To summarize, I am considering: 1-Buy a brand new unit at $730 and installing it myself
2- Have a local shop install a "rebuilt" unit for $800 with the install
I am pretty handy and am strongly considering removing the old unit and installing a brand new one myself. I have taken apart the motor and replaced motor parts without any issues if that sheds any light on my level of mechanical competence. It is my understanding that one must take great care to not damage the laterals, and to load the sand to the proper level. My push/pull valve seems to be in good shape so I think I can avoid replacing that. Am I in over my head if I install it myself? Is it likely I will damage my fancy new tank or motor if I do it myself? It just seems like $730 plus sand is a way better route than a rebuilt unit for around the same money when there's no telling how much life I will get out of a rebuilt filter tank.
I found this video detailing a sand filter install and they address how to not damage laterals, and the video overall seems pretty good. Any thoughts or suggestions on other guide DIY guides for this job? Sand Filter Install
Thanks so much, any advice is much appreciated!
