Installed new pump.and it is leaking
If you replaced the total pump (not just the motor) then you could ask for a new pump under warranty. It should not leak if it is brand new and there is no reason to mess with those bolts if you are just installing the suction and exit plumping.
Did you replace the whole pump or just the motor?
