- Apr 15, 2018
- 201
- Vinyl
- Pentair Intellichlor IC-20
Hi- am upgrading from old superflo to intelliflo vsf. Installer alerted me to likelihood of changes on my panel.(easytouch).
Presently superflo and heater are ganged together on the pump relay.
They said the new pump will need to be taken off the relay and wired direct to the breaker. Ok-I guess they are right?!
So do I need a new breaker? Do I somehow move the heater off this relay now too? I thought the reason to have heater and pump on same relay was to ensure synchronization in operation.
Would I just perhaps pigtail the 2 load feeds off the breaker so they run direct to pump (240v) and then continue to feed heater in relay as is?
The new pump is apparently totally controlled via data cable.
What is the common or preferred way to do this?
