While closing my pool last season, my relatively new Superflo VS (2 seasons = 10 months of use) started losing voltage/tripping it's breaker. It happened relatively quickly after running dry for a few minutes. I had never had any electrical problems with my setup before.
The problem seemed to go away after a day or so, but it was as I was closing the pool - I'm not sure I have enough data to gauge whether the problem will show up again this year.
I have opened the pump up, and have found pretty significant gouging on the front of the impeller and on the bronze diffuser bushing. There is also some white powder/residue on the backside of the seal plate (the motor side of the seal).
Is there any reason to be concerned about this wear? Should I replace the components?
Any chance this could be causing water to leak into the motor?
What could the white residue be?
Thanks
Thanks
