I've quoted and reordered your post =) And shared lots of personal experience & research info!
- I would *suggest*
-- assume starting PH of 8.2
--- treat with an initial target of 7.8 (using muriatic acid), as a safe starting point
---- you do NOT want to go to low/to fast
----- get the PH into a range where you can test it, then start lowering/aiming for a comfortable/treatable PH
- Does the TF100 not have a acid demand test? or Total alkalinity?
- 75% of what? CYA takes at least 24hrs to fully dissolve and disperse (and properly register in the CYA turbidity tube test), you do not want a CYA level over 50 for most pool situations. We have intense summers here and our CYA is kept at 30-40, no green & no problems with large FC loss (we DO use a clear bubble solar cover, I'm sure it's related)
- Per ABCs of Pool Water Chemistry, find the CYA dosage for your pool and put that amount in a (clean) sock in front of your return, it is safe to squeeze the sock to help with dissolving.
- After that *Assume* your CYA level stays the same. You can test CYA bi-weekly or after large volume of water replacement
Yes, you should test your FC/CC or PH about 1 hour after adding each treatment (per SLAM Process process, still not testing more then once per hour)
3+) FC is over 3ppm but under your pool's CYA shock level (FC=16 @ CYA=40)
0) CC is 0 or 0.5pp (Just for example:: this means if you are using the yellow dye drop test, the sample is the SAME color @2-5sec AND at 3min!! If it gets darker after 5 sec, it's NOT safe to swim yet)
7.2) PH is mid range (7.2-7.8)
- It would be recommended to add the shock level of chlorine in the evening after everyone is done swimming. (plus less UV interference)
- It's a safe practice to always test chlorine & PH before swimming (especially when things aren't stable, yet)
! If you can "smell" chlorine, it's not safe to swim!
Sorry for the info overload!
Yes, you must balance the PH first. ABCs of Pool Water ChemistryIs there a correct order i need to achieve target numbers?
- Some as in very little, it doesn't take much PoolMathDo i understand correctly that if ph is higher than what kit can read i need to calculate it in pool math as 8.2 to determine qty of muratic to use?
and ph was over what k1000 would register... , some muratic to lower ph
- I would *suggest*
You will want to add enough for a (daily) maintenance target of FC3-5 [FC/CYA][/FC/CYA], a higher FC level will be required for SLAM ProcessTf100 kit arrived today. Tested chlorine/ph with k1000 kit. Fc didnt show up ... 128 oz of 10% bleach.
For reasonable SLAM Process (since you are starting at 0, as already recommended above), I wouldn't dose CYA over 30 [FC/CYA][/FC/CYA]Did cya test, it was 0. Using pool math I need just under 8 lbs of stabilizer to hit 75 on cya
- You can slowly add bleach (with pump on) in front of a return at anytime (as long as noone is in the pool). It just won't be able to resist the UV rays without CYA present.Like don't add bleach till cya is at 75%?
I thought I read something that said if i use dry stabilizer that i need to wait a week to retest.
No = Do not add the chemicals at the same timeDo I add all these chemicals one after the other, wait 5 min and retest?
Within a couple hours *IF*In the pools current state, if i get the chemicals right, how long till I can swim?
Never be sorry for asking questions! It helps all of us get it right the first time! (or nearly so)Sorry for these noob questions, just trying to get the kids in the water with out their hair falling out or melting skin
