I ordered the Taylor 2006 test kit and should be here by Friday. I’ll post the results right away.
I also ordered the tool to remove the cover. I plan on pulling back some of it to get an idea of what I’m up against.I ordered the Taylor 2006 test kit and should be here by Friday. I’ll post the results right away.
I was able to pull back the cover to a peek at what the conditions are. The water was relatively clear and there is of course the expected black muck on the bottom. What is a little concerning is the liner appears to be pulling out of the trim that holds it in place.
I’m starting to realize the person we bought the house from wasn’t entirely truthful about the condition of the pool. It is entirely possible he never winterized it when it was last closed up. The neighbors say they haven’t seen it open in at least 10 years. View attachment 398768View attachment 398769
Do they make a vacuum that’s not pool pump operated to suck some of that junk out? I think I’ve seen one that was electric, but it might be one of those professional equipment deals with a price tag to match.So you have a chose or three:
-cover it back up and wait a bit until you get into the house good to try to clear it.
-pull that cover back and start the SLAM with the water that is in the pool. Just find a good source of liquid chlorine. You will be using a lot of it.
-pull the cover back and drain some of the water. Leaving enough water to cover the bottom step. When you are draining you can use a hose to suck up some of the muck to get it up and out. Then SLAM when the pool is refilled.
I would start setting aside some pennies for a new liner. That pull out place can be worked with and we might be able to get it back in place when you have a nice, sunny, hot day.
I didn't like the pics, but i rooted for you anyway. But HEY !!! We don't have to clear a swamp now.This is what I had expected
Maybe he is expecting to get alot more business from you when you need more work, like the heater, so he is getting his foot in the door. Maybe he has low overhead and he is still making plenty. It's a fair price and the others are overcharging because people are paying it.see if $4500 for a 18x36 lazy L pool liner installed is a too good to be true price? The guy seemed legit and knowledgeable but the price is way less than any other quote I’ve received so far
She is a wise gal.I am going to take @kimkats advice and check references.
As long as the references check out. I had my liner replaced and had to have the fiberglass steps busted up and replaced. I used someone I knew that doesn’t even advertise. I paid $3000.00 for the liner and $4000.00 for the steps. All of the other companies wanted more then that to just replace the liner. They did a great job. Point is that yes if you look hard enough or know where to look you can find people that cheap that does competent work. I watched them bust up and replace the steps. That was an insane amount of manual labor. None of the other companies wanted to touch them, but they needed to be replaced.I had a pool person come out today to look at it and give me the low down. The liner has turned into a plastic shell and is brittle. This is what I had expected. He can replace the liner and get it going for us relatively cheap and quickly.
I just wanted to check and see if $4500 for a 18x36 lazy L pool liner installed is a too good to be true price? The guy seemed legit and knowledgeable but the price is way less than any other quote I’ve received so far
