Hi,
About 5 years ago, my inground pool stairs cracked (vinyl pool from 1985 with fiberglass stairs) and required a complete repair. The company that fixed them sanded them down, put fiberglass sheets on each step and repainted them with a white gel coat. All was well, but the stairs are now having parts of the gel coat chip off and I am seeing hairline cracks in the paint (stairs don't seem to leak). The company that did them went bankrupt and I am now debating if I should redo them myself.
My plan was to remove any loose gel coat, fill in the voids with resin and then paint over the existing gel coat with another coat of gel coat (it seems gel coat to gel coat will bond).
Has anyone ever tried this?
Any suggestions on products I should be using for the job?
I have used resin in the past but not for underwater applications...
I have also never painted with gel coat - but it seems it can be reapplied with a brush over an existing gel coat?
Pool liner is currently out so I have a chance to work on it over the next couple of weeks.
Any comments / suggestions would be greatly appreciated.
Thanks!
Thanks!
