- May 23, 2015
- 25,709
- Plaster
- Pentair Intellichlor IC-60
Hey y'all ... title says it.
This morning I awoke to a flood in my walk in closet. The closet room shares a common wall with an outside utility closet where the original builder of these homes STUFFED the HVAC furncae/air-handler and one of the 50-gallon tank gas water heaters (my house has split systems, one set is in the utility closet, the other set is in the garage). Anyway, the flood in the closet was caused by the water heater leaking. Tank has a hole somewhere in it. Spent the better part of the day drying out the AC air plenum which sits below the base of the air handler where the equipment is installed (goofiest way of doing an AC system I have ever seen ... literally HATE it but it's what I have). So all flooding is fixed and walls are being dried out (I'll get to any drywall repair later ... no one sees the walk in except me and the little lady so I have no one to impress ....).
Anyway my options are to install a new 50 gallon tank water heater or consider going with tankless. My initial thoughts are this -
1. It's gotta be gas because that's what I have.
2. It needs to be compact because space is limited.
3. Its in an outdoor utility closet so "out of sight, out of mind, never gets looked at regularly" is the guiding principal - therefore I need something that is ROCK-SOLID in terms of longevity and operations. I am willing to sacrifice bells and whistles if the unit will have very low downtime. I don't need fancy, I need reliable.
I'm intrigued by tankless but the array of options and manufacturers is endless. I'm looking for comments from folks that have them and can speak to their performance and reliability. I'm ok with a little bit more maintenance than the traditional tank heater (drain every 6 months or so and change a Mg anode every couple of years is about all they ever need) as long as the unit will go the distance.
All thoughts, opinions, and recommendations are welcome.
Thanks in advance!
Thanks in advance!
