- Jan 5, 2020
- 19
- Plaster
- Pentair Intellichlor IC-40
Hello!
I recently moved into a place with 36,000 gallon vinyl liner pool.
i have backwashed the sand filter, but I still wish the vacuum would be stronger. It has one 86 gallon/min 1 horsepower pump. There is only one suction side pipe (with 1 skimmer and 1 vacuum port both connecting to the same pipe). Vacuum port is closer to the pump/filter.
I’m wondering if I can block off the skimmer to increase suction to the vacuum port?
Thank you in advance for any advice.
