- Apr 10, 2018
- 6,360
- Plaster
- CircuPool RJ-45 Plus
That's the type of check valve that is used for a spa blower.
It's the same company that makes the blower and the check valve, so the check valve was probably supposed to be installed on the blower line.That's the type of check valve that is used for a spa blower.
Just a heads up. The SWCG circuit breaker is the 12 amp gray one (low voltage) to the right of the touch screen.@Jimrahbe thank you for your comment. I checked the circuit breakers on my panel and took a photo of it and attached here (no circuit breaker for SWG??) Should the builder have added it? Is any other thing missing?
By the way, I found this valve left on top of the controller. Do you know what it is?
Probably an uneducated question, but why wouldn't a spa return be needed? Just trying to understand.You don't need the red circled spa return but they installed it.
You can’t. At least no way that I can think of (I tried multiple methods!). But it is labeled as the Intellichlor circuit.C,
You can shut off a regular circuit breaker.. I don't believe you can manually shut off the little grey ones...
I think my question was simpler than that: If a spa return is not needed, how does the water return to the spa? Again, just trying to understand how the spa/pool plumbing magic happens.It is explained in post #12 & #14
@Candurin Thank you for your comment. Do you mean the installation of the surge protector is not correct in my panel? Is it an issue that I should talk to the builder?Just a heads up. The SWCG circuit breaker is the 12 amp gray one (low voltage) to the right of the touch screen.
Also, it seems odd the surge protector on your panel is the last one. Usually surge protected panels have the protection at the very first breaker slot.
Pentair load center feed from the bottom. Our electrician said the surge should be in the 1st spot ie bottom.Also, it seems odd the surge protector on your panel is the last one. Usually surge protected panels have the protection at the very first breaker slot.
@ajw22 I told the builder my concern regarding the lack of the valve on the spa return pipe and the continuous flowing of water into the spa, and he added a valve. Thank you very much for your comment. Now, I should shut the valve off and schedule the spillover mode to run for the periods of time (morning and afternoon), as you suggested. I have a question about pump running time for the pool, and appreciate it if you could help answering. My pool builder has scheduled the pool to run from 8am to 7pm. I am wondering if it is necessary to run the pool pump for such a long time? What is your suggestion and how long do you run your pool pump every day?Yes. You need a valve at the elbow leading into the spa return pipe above the check valve.
Without the valve water will always be flowing into your spa when in POOL mode and over the spillover. You will not be able to regulate how much water flows through your pool returns versus into your spa and over the spillover. Your pool returns will probably have a low flow and not be very effective.
You will also not be able to turn off the flow to the spa and stop the spillover of water. Continuous running of the spillover will cause rising pH and you will have much more acid demand to keep the pH within the 7's.
You will make any flow adjustments to your pool returns by varying the RPM and flow of your VS pump. You don't need a valve on the pool return pipe to do that.
Your IntelliCenter automation will have three modes:
We recommend you run your pool with the spa return off and schedule the SPILLOVER mode to run twice a day for 15 to 30 minutes to refresh the spa water. I run my spillover at 9am and 5PM for 15 minutes. That puts chlorinated fresh water in the spa for the start of the day. Then it replaces the water at 5PM for the overnight and replaces any chlorine lost during the day.
- POOL mode - suction comes from the skimmers and returns to the pool (and the spa depending on the setting of the new valve we are discussing)
- SPA mode - suction comes from the spa and returns to the spa
- SPILLOVER mode - suction comes from the pool and returns to the spa and then water spillsover into the pool
@ajw22 Thank you for your reply. I checked the RPMs of my pump for different functions (2500 for the pool mode, 3200 for the spa mode, 2800 for the spillover (spa waterfall) mode, 3450 for the high speed, 1800 for the freeze protection, and 2900 for the heater). I assume it has been set by the builder. Any suggestion?Your minimum pump runtime is determined by your SWG % and the need to generate the daily amount of chlorine needed by your SWG. After that it is personal preference when you want skimming done in your pool.
I run my pump 24/7 at low RPM.
