- Apr 19, 2019
- 331
- Vinyl
- Hayward Aqua Rite (T-15)
So I dropped a sample off at my builder, because he wanted to test my water. His test is saying I need 244lbs of salt added to my pool, my test using k-1766 (new reagents) shows I need to get rid of some. Last test showed 5000ppm. Is it possible the test isn’t working right and something in my water is affecting my results?
he also wants to add calcium up, alkalinity up, and 3 bottles of iron out. My water is perfectly clear right now.
my last tests using new reagents showed TA at 60 CH at 150 FC 3.5 CYA was at 45, but I added 7lbs the other day. This morning FC was at 2, salt cell needs to be cleaned so it’s not working right now. My wife is adding a gallon of shock this morning to raise FC up a bit.
turned heater on other day so water is now 80*
im not home right now so will be running the tests tomorrow morning, again. I just got all new reagents, so I know those are good. And using the tests last year I had absolutely clear water.
it’s so clear you can even see the sand at the bottom. Robot made short work of it though.
