Hi all, purchased this house with a pool, and the skimmer, vacuum, and main drain lines were broken, and (see Below)
we wanted the lines fixed before we closed. Well, the realtor had someone he said was a “plumber”, and had him come out and run lines to pump as agreed. We are new to pools, so we knew no difference in the right way or wrong way to run lines. I have screenshots showing the way he ran them, and looking at the first photo, the line from the left is main drain, directly across is skimmer, and the other closer to filter is vacuum. Pump is a Hayward super pump. From reading some of the posts, I know the line going into pump in wrong, but I’m having trouble getting it to prime. Can someone advise? If these are wrong, can you tell me the correct way to run them?
