- Mar 23, 2012
- 9
- Plaster
- Jandy Truclear / Ei
So, i’m at the in-laws... they have a SWG, and a retractable cover.
Right now, the Salt level via test kit is ~2000ppm. The SWG, Pentair intellichlor, says it requires 3600ppm (printed on the unit).
The pool is always low chlorine. Either 0 or 1 ppm. I have been adding bleach (like we do with our home pool) whilst we’re here, to keep it sanitary.
My in laws have a pool guy. He says that he keeps the salt low to prevent the SWG from generating too much chlorine. In the past, when the pool cover is on for extended periods of time, the Cl climbs really high, I assume because it’s getting no UV light from the sun. However, the pool cover is off a lot when we’re here.
Question is - does the SWG produce any chlorine when salt is low? Or is it essentially off?
Should I go any buy salt, and just add it to hit ~3600ppm so the SWG is happy, and then dial the generation rate and pump time to get things dosing correctly?
