In Ground Spa Leak - ? Fill line
skinnycow
2
Los Altos, CA
Everything had been going well with taking care of our stand alone in ground spa thanks to this website until we developed a leak last week.
We are loosing 1-4 inches per day from the spa without an obvious area that’s leaking. I was able to do a partial dye test today (all that’s left are the main drains at the bottom of the spa; it got too dark to keep going) and noticed that water is flowing back through the fill line that connects to a manual valve located at the equipment pad. I have noticed that the valve leaks when we turn it on to refill the spa, but it’s been going on for a long time even before this leak and it’s pretty minor. Would a broken valve mechanism be sufficient to cause this type of leak/siphon? Or do I need to keep looking elsewhere, like an issue with the underground pipes?
mknauss
37,031
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Welcome to the forum.
That much water should be easy to find. The valve you posted a picture of is an anti siphon valve. That is for a fill up line.
Does your filter have a MPV and a waste setting?
skinnycow
2
Los Altos, CA
It doesn’t. The water level stopped dropping where the fill line enters the spa. I plugged it with a stopper and no more leak. There must be a leak in the pipe underground, maybe a joint came loose or something. The fill line is non essential so will just plan to use the hose to top off water loss from evaporation.
mknauss
37,031
Laughlin, NV
Fiberglass
Good to hear.
