I have 2 check valves and I'm not sure which is failing. After the spa had refilled I turned off the pump and disassembled both check valves as well as the Jandy valve and everything looked fine to my unprofessional eyes. I would have expected the water level in the spa to drop while the valves were taken apart but nothing happened. The Jandy vale is always kept in the position shown in the attached photo, fully closed on the spa suction side. This has been going on for a few months. The spa did hold the water level in the past. When I opened the check valve nearest to the Jandy valve it was dry inside but when I removed the inner workings the water level in the pipe below did fall.
I appreciate any and all any suggestions for repair.
