I'm posting a youtube link to see me walk through everything about this but essentially, I can't seem to get rid of the air bubbles infiltrating my system.
I've got no water leaks first off. Secondly, have new o-ring on lid with gel.
Have check all suction lines, valves and replace o-rings in jandy vales with gel as well.
Check join, no air suction, used foam, soap, and water and nothing shows a suction leak.
I'm no guru so looking for the cause is beyond me at this point.
Logically if none of the above, I was thinking perhaps it was a cracked line underground but I've moved the jandy vales shutting off one side (skimmer/bottom drains) and the kiddy pool side and no difference noted, same ole bubbles.
Hope you've got a better clue than me at this point.
Thanks In Advance to anyone who comes up with something.
Here is video link...
