In Floor Cleaning System - How Should it Work?
Lynn,
Do you have some kind of debris basket for the IFCS?? If not, where to do debris go? They obviously don't pass through the filter...
Sounds like you have a pretty good handle on it now... :goodjob:
We've noticed that they aren't pushing out a crazy volume of water now. I assume it's because they don't have as much pressure. We can tell they are running because they pop up and the water moves a little in the area, but before they were making the water jump onto the coping on the more shallow heads and that's not happening anymore.
I am pleased that we reached a state of satisfaction. If you ever need to adjust the flow of water, just remember to go to the speed setting screen for either pump and make adjustments - either lower or higher to meet your needs. From an earlier post it showed that Pump #2 was at 1750rpm For vanishing edge. Good Luck and come back for any additional questions.
You have a beautiful view. Just curious - are you overlooking Lake Travis? I am very familiar with the Lakeway, Hudson Bend, River Place, Steiner Ranch and surrounding areas in Austin.
Reactions: Jimrahbe
Thank you so much! I adjusted the pump to lower the cleaner speed just a little more and everything is working beautifully. I’m so grateful y’all were able to help me with this.
Yes, our view is of Lake Travis! We’re on the south side of the lake just outside of Lakeway. It’s a really spectacular lake even when we’re in the middle of a drought like we are right now.
Reactions: HermanTX
