So after your last response, I went to the panel and the pump display now says Display Not Active (no idea why it changed). I selected VS as the pump type, assigned the circuit as "Pool". Then hit the filter button and it started right up. Seems to be running fine now, but will set start/stop times and see if they work. Will also assign speeds/programs for spa and heater and see what I get. I assume it is ok to have it set as VS even though it is VSF?I'm not sure why it is not working.
Maybe the older software is not compatible with the newer software?
Maybe someone else will know.
Also, Thanks for the software update link/info, I'll look into that as well
