I'll post pics below; but it seems fairly straightforward so far but there are things that are new to me that I don't understand.
Pool Layout
- I'm guessing roughly 30,000 gallons, it has a proper deep end (8 feet), vinyl liner
- 4 returns
- 2 drains
- 1 strainer basket
- Fiberglass steps
- Typhoon slide
- diving board
Pool System - 6 'on/off' blue valves. I think I *kind of* know what they do:
- Rear 1 (open this to push water to waste)
- Rear 2 (not sure..maybe close this one when opening the cartridge filter to cut off water coming from the pump?)
- Front 1 (in from strainer)
- Front 2 (in from drain)
- Front 3 (TO pool returns)
- Front 4 (OPEN - TO water slide; generally leave it closed..especially since slide is broken right now)
Pump model below. Seems basic and very similar to my old pool. No questions here.
Cartridge Filter - This is a huge pain in the butt it appears. This was left completely clogged and had a pool company come out since I've never dealt with one of these. I watched the steps they went through to release the water, open the filter and 'backwash' the nasty water but I don't have a clue what they did. I was in the middle of moving so I couldn't sit and take notes. They took the 4 cartridges to the pool store and soaked them in muriatic acid and pressure washed them off. Before they cleaned them, there was zero water flowing through the returns into the pool and its much better now. Anyone with a cartridge system have some tips & tricks?
UV Sanitizer. I. HAVE. NO. IDEA. I think this helps to keep the water clean so I'm not putting as much chlorine in but this is a mystery device.
1. Do I have to service it regularly?
2. How do you service one of these?
3. What does this actually do as far as reducing the amount of chlorine needed or keeping the pool clean? I don't know what to think of this.
Intermatic Switch. Does this make my life better in any way? I installed an intermatic switch at my old pool that I could turn on/off rather than flipping the breaker each time. This does not appear to have any switches or way to turn the pool components on or off. Looks like I'm back to using the breaker for everything which I don't like.
Finally, this little guy gets an amazing amount of gunk into his filters every couple days. I'm hoping this is just pollen & stuff from being spring as we don't really have any trees hanging over the pool. I have him set to run once every day and he tends to get hung up on the 2 drains at the bottom of the pool.
That's about it! I would LOVE your thoughts on this system especially things I need to watch out for or nuances to how to keep things running smoothly.
Pool Layout
- 4 returns
- 2 drains
- 1 strainer basket
- Fiberglass steps
- Typhoon slide
- diving board
