Pool water is clean and clear. Our SWG is sized too small (IC40 for a 32k pool) so in summer I find myself adding some liquid chlorine here and there, which I'm fine with but lately I feel like the chlorine is having a harder time keeping up. After adding MA and Chlorine (seperate times), water is:
FC 5.0 / CC 0.5
pH 7.5
TA 40
CYA 50
I'm usually battling pH rise, my pool loves to sit at 8/8.2 and as TA has slowly lowered over time, my pH rise has slowed a bit compared to previously when my TA was higher at 70-80. So should I leave it and not add baking soda? And if I leave it for now, at what point do I add baking soda....it's already less than the recommended level for a salt water pool.
As for CYA, I'm assuming I might be going through chlorine a little quicker as my CYA is too low....what would be the ideal # to raise it to, another 10? 20? Or leave it at 50 and keep monitoring? I guess I could add chlorine pucks which helps both the chlorine levels and the CYA...
FC 5.0 / CC 0.5
pH 7.5
TA 40
CYA 50
