- Mar 1, 2013
- 107
- Jandy Aquapure 1400
Living in North Carolina most people leave their pools open year round as I understand it. I have two water features I’m a little concerned with
1) is a 3’ sheet descent.
2) is a 12’ negative (infinity) edge that spills over into a smaller pool. The PB told me to keep them on their normal circulation schedules and they should be fine. Basically do nothing. Freeze protection will engage the pumps when freezing temps arrive.
Also I’m unclear if I should remove the salt cell and dose chlorine manually during the colder months.
I’m thinking I’d like to close the smaller pool (catch basin) but I can’t see how I’ll stop water from spilling over once the larger pool area fills up. I was thinking sandbags on the negative edge ledge.I mostly worries about water going over the ledge, freezing and causing damage from the thermal cycling. Just not sure what the recommendations would be.
The sheer descent I can blow out and make sure the valve doesn’t engage to keep water out of it until the spring.
Thoughts how to keep this going or which parts I should close and how?
Thank you. Mike
Thank you. Mike
