- May 29, 2018
- 155
- Fiberglass
- CircuPool RJ-30 Plus
Yes a whole month would get you a clear, TFP pool. 1-2 weeks of dumping 12% liquid chlorine should do the trick. Just before you leave, clean your filter, plumb in a SWG system, test for a week and let it go. Take your trip and enjoy knowing a crystal clear pool will be ready for you on your return!
For most of June, I have cleaned the skimmer sock, run the pool robot daily or every other day. I have only regenerated (bumped) the Hayward DE 65 unit once in 6 weeks of use, even though it had only gone up 5 psi (10 psi recommended). I have tried to test chlorine, PH levels daily since the new pool, SWG and I are in a learning/trust phase. I've been testing everything else only weekly as well as brushing the sides and ledges.
With the SWG system, I don't smell any chlorine nor feel it after swimming.
