- Dec 11, 2016
- 61
- Jandy Aquapure 1400
New house with 20 Year old pool.
Single pump for pool/spa. Extra pumps for waterfall, slillway, spa jets.
I cannot figure out what the purpose of the bypass return line is.
See picture. Return manifold has 5 vertical pipes.
Far right spa retrun
Next to it pump/heater return coming up from ground.
Next to it pool return.
Next to it is a bypass with check valve.
Next to it is pool cleaner. This is the weird bottom of pool pop up heads that rotate. No longer in use.
What i cannot figure ouy is the bypass with check valve. What is the purpose of that?
Thanks
Ken
Thanks
Ken
