I just purchased 55 pounds of boric acid granules from Duda Diesel to help with the rising pH levels I typically experience because I do not like handling muriatic acid. My green pool (mesh cover) was opened last week and the pool company added algaecide and chlorine. I bleached and backwashed 6 or 7 times until the pool was crystal clear. Otherwise, I only added salt so far to get my SWG working. I need to do a a bit more balancing but I want to make sure I don’t do something counterproductive since I will be adding boric acid for the first time (hopefully by Wednesday night). Below are my current readings. What should I adjust, in what order and to what level, before adding the boric acid granules? I read other posts but most seem to focus on adding borax and muriatic acid which is a different process as I understand it.
FC 2
CC 0
pH 7.2
TA 50
CYA 0
CH 100
Salt 2800 (ideally should be 3400 per SWG)
Thank you in advance for any guidance you can provide.
FC 2
CC 0
pH 7.2
TA 50
CYA 0
CH 100
