Ichlor30 "stuck" in boost mode
brandon12345
6
Kansas City, MO
I removed my Ichlor30 to do regular acid cleaning and after replacing it and restoring power to the SWG, it is "stuck" in boost mode for 24hrs and will not allow me to exit boost mode. Once that 24hr cycle completes, it reverts to 0 output and when I attempt to adjust the output to the desired setting, it goes right back in to the 24hr boost mode cycle and repeats the same behavior. Anyone else run in to this issue? I've tried cutting power for 10+ minutes (maybe I need to cut power for longer?) with no success. Anyone run in to this issue and successfully troubleshoot? The Ichlor30 is about 3 years old and probably has ~6,000 hours on it.
You probably have a dead cell that needs to be replaced.
