Hello,
I replaced my IC40 after 9 years with the IChlor 30 from Pentair. I bought it on Ebay but after 1 week there is no power.
I have done the following:
1. Checked the connections from the IChlor to the Power Center to ensure they are snug and secure.
2. I have checked the breaker box but all is looking good.
3. I opened up the Power Center to look at all the connections and they are secure.
4. I checked the fuse and it has not blown. The line inside fuse is not blown but it has an arc to it. I also checked for continuity.
The next step to is grab my multi meter and check the connections.
I have checked the power coming to the Power Center and it is at 120 volts. When I spoke to a Pentair rep he had told me to check the pin connections where the IChlor connects to the Power Center. What is the best way to check for this and what setting on the multi meter?
Here is the email from Pentair:
David,
As far as voltage troubleshooting is concerned, we just need to verify the voltage going into and coming out of the power center. Incoming voltage should be 90-130 vAC and outgoing voltage should be 22-39 vDC.
David
David,
David
