It has skimmers but not sure bout a main drainDoes your pool have a main drain and skimmers, or just skimmers?
Just skimmer I thinkDoes your pool have a main drain and skimmers, or just skimmers?
Tablet chlorine feeder. Usually used with Trichlor tablets. Never mix different types of tablets in a feeder.What are theses?
Ok. If you look at the Jandy valve you will notice it has an "OFF" placard. That placard will point to the pipe that is currently closed off. Right now in your pictures, the valve is positioned so that both skimmers are fully open. If you have skimmers only in the pool, this is the correct operating position. You can identify which pipe leads to which skimmer by moving the off placard to one pipe (left or right side). Check at the pool which skimmer has stopped flowing water, and you know that pipe is attached to that specific skimmer.It has skimmers but not sure bout a main drain
What tablets?You should remove the tablets ASAP. They will destroy your SWG cell.
O that is the first time I’ve opened that. So have they been there since the pool was built 3 years ago? And would that keep the salt cell LED light from coming on?
SWG's typically last 6,000 to 10,000 hours.If I’m reading the display screen right I have 6541 hrs on my iCHLOR 30 and they are built for 10,000hrs. So could it be something else that’s causing my salt LED light to be off?
If they've been in there for 3 years and your chlorinator was set to position 5, there's something wrong with the chlorinator. Either way, the effects of acidity happen over time, not overnight by eating away at the rare metals of the SWG cell.O that is the first time I’ve opened that. So have they been there since the pool was built 3 years ago? And would that keep the salt cell LED light from coming on?
Use liquid chlorine as a supplement for your SWG when needed.Tablet chlorine feeder. Usually used with Trichlor tablets. Never mix different types of tablets in a feeder.
The acid in tablets can damage any other equipment near the tablet feeder, and we do not recommend the use of them.
Please confirm you set production to 100% and the cell light stayed off……If I’m reading the display screen right I have 6541 hrs on my iCHLOR 30 and they are built for 10,000hrs. So could it be something else that’s causing my salt LED light to be off?
