ICHLOR 30 Low Chlorine production
Jaime Ramirez
3
Monterrey Mexico
I just started a new pool, inground plaster 4,800 Galons, with an Ichlor30 and 1 HP pump running about 3 hours a day at 100% output, Salt level is 3100 PPM, Cyanuric acid around 50 PPM, however, the chlorine level is VERY low....any ideas?
ajw22
11,299
Northern NJ
Welcome to TFP.
What test kit are you using?
What is your complete set of water chemistry?
FC
CC
pH
TA
CH
CYA
Running your Ichlor30 at 100% for 3 hours a day will give you about 3ppm of FC. That is normal daily pool usage so I would not expect your FC to rise at all. The FC the SWG generates will be consumed every day by the suns UV rays.
I suggest you read ABCs of Pool Water Chemistry
Jaime Ramirez
3
Monterrey Mexico
Welcome to TFP.
FC
CC
pH
TA
CH
CYA
Hi:
Thanks for your reply, here is the chemistry:
FC...very low under 3 ppm
PH 7.4
TA 190
Total Hardness 600
CYA: 50 ppm
Any suggestions??
Thanks
