- Jun 18, 2019
- 579
- Plaster
- Pentair Intellichlor IC-60
I couldn’t sense from that how the three wires work as most of that states to wire a third party sensor to green and white.
Do you have 3 wires or 4 wires?
What color wires do you have?
Read https://www.pentair.com/content/dam...low-switch-replacement-kit-manual-english.pdf
And see step 6 on page 5.
Thanks, it seems basically the green is no longer used if you get a new flow switch with an old unit. Did I read that right?
That’d mean if I disconnect just the white wire, in spirit that should default me to 77. That’s how I read it.
See what wires you have and cut the white wire.
If there is also a green, cut that as well.
Trying just white first since maybe the green isn’t in the cell? Will tape but these are so tiny it’s actually difficult to cut.I would cut the green and white wires and then see what the salinity reads when you start it back up.
Tape the ends of the cut green and white wires so that they don't make electrical contact with anything.
Ok. Cutting just the white wire should work because it disconnects the temperature sensor.
If you did the More button test again it should show sensor bad, which should make the temperature used in the salinity calculation default to 77 degrees Fahrenheit.
What is the water temperature and what is the salinity reading now?
