- Jun 18, 2019
- 594
- Plaster
- Pentair Intellichlor IC-60
The battle with my IC60 continues. In late March the thermistor went out. I got a replacement flow sensor from Pentair and put it in and the unit has worked flawlessly until yesterday. Now the IC60 reports red flow (there's great flow, clean filter, extremely clean plates, great pressure on returns, etc.). Then without any real significant change it'll start working (green flow and cell) and then I'll come back and it'll be red again. I've tried running at max pump speed as well, so it's definitely not a real flow issue.
Initially I thought maybe all the rain was getting some connection wet, but given it goes in and out even when it hasn't rained in hours, I'm not thinking that's it. The flow sensor itself looks to be in great/new condition, it's installed in the right arrow config (I've verified the arrow is in the right direction). I did open a case with Pentair but they said there's like no warranty companies in Austin available. I'm also concerned that the warranty company will come by and it'll be magically working during that period as there's no specific formula to make it not work. Anyone got good troubleshooting ideas here? Even with no flow, it does report a relatively accurate salt level.
Once it's completely dry, I'm doing to wrap it in saran wrap to try and rule out water. If I remove the flow plastic cover, I can see a little moisture on the unit and water drops going into the hole that feeds power and the flow sensor.
Thanks for the help!
