A couple of thoughts. Does the psi gauge rest at "0" when pump is off so we know we have a good gauge. The diverter valve after the cell has no handle so how do you know that valve isn't restricting flow and are you sure the pump is up to snuff and putting out what it should. can you amp out the pump wire to see what amperage it's pull which is another tell tale of pump condition.
