Hi,
We just opened the pool for the season and our Intelichlor IC20 has a solid red flow light as well as an alternative light on the salt level from good to low (red and green). The manual suggests an obstruction in the cell, dirty filter, closed valves, or insufficient water flow.
1.) I've backwashed twice and cleaned the filter near the pump. The skimmer is clear. I've also rinsed and recirculated the water.
2.) The pressure at the return jets is strong
3.) I've cleaned the cell with muriatic acid and removed all the buildup (there was a decent amount).
4.) I tested the salt levels and it's still below the recommended levels. (working on bringing the levels up). This will obviously affect the salt light, however, I would think the flow light might be a different issue.
The device only has about 2,000 hours on it when running a test.
Anyone experience this before or have any other thoughts?
