Welp,
As the title says, my IC 40 is blowing fuse after fuse.
A couple of days ago is when I noticed the lights on the cell wouln't fire up. I put some bleach in the pool and waited until today to look at it further. My SWG is just finishing 5 years of trouble free operation.
The fuse which was in the unit was a 8A. I went to Autozone and ended up with a pack of 10A fuses rated for 250V. Just for info, the 10A fuses are not slow blow ones, I couldn't find any of those anywhere.
Anyways, came home and installed a new 10A fuse. It blew in about 1/2 second.
Opened the Power Box and looked inside with my Tactical flashlight and my 6x magnifying glass, no obvious issues like burnt wires or anything.
Oh yeah.. before I went snooping into stuff, I measured the voltage and its perfect at 220V.
Put in another 10 amp fuse and another 1/2 second later, instant blow.
hummm...
So next I un-plugged the cable that provides power from the Power Box to the Cell, installed another 10A fuse and turned on the power. The fuse did not blow, the little Green LED light on the circuit board in the Power Box lit up and everything looked fine.
So I turned power back off, plugged in the cable and turned it back on and Pow. Blown again.
Using my super duper tactical flashlight and magnifying glass, I inspected the pins in the power cable connector and don't see any signs of arcing or burnt pins on it.
Unless anyone knows anything else I can check, I'm leaning towards deciding something in the cell has gone awry and the cell needs to be replaced.
Give me your ideas if you have any.
Ready, GO!
Thanks
hummm...
Ready, GO!
Thanks
