Hi,
i recently got a single speed pump replaced with a jandy VSP. it is all hooked up to the iaqualink. I am playing with the VSP speed setup and have few question on how the solar heater is handled in terms of RPM and also how to debug the JVA
1. The schedule and the speed setup is as attached in the pics. will the VSP speed change to the solar heater speed 2750 whenever the solar JVA is enabled due to temp delta between pool and air? or do i need to make any change for it to behave in the way i described? i called up the iaqualinik support but they were not very helpful and said, i should assign an aux to the solar heat in the VSP speed setup but i don't know how to do that..Will try calling them again if i don;t get too far from this thread.
2. how do i test the solar JVA? there is a marked difference in the temp between the air and the the pool and earlier i used to see "solar heating " message in the iaqualik app which i am not seeing anymore, and neither is the JVA in the solar heat position. I tried manually setting the switch below the valve but it does not do anything. has it gone bad. any other debug steps?
