iAquaLink Not Powering Up
xford66
16
Georgetown, TX
Looks like my iAqualink controller has died but wanted to check with any experts that may have tips to confirm.
Note I did read through old posts like: AquaLink RS8 - NO POWER ANYWHERE
Checked power at the back of the board, seeing 26vac. pulled fuse and ohm'ed it out, good.
Found a corroded part on the board (circled red in attached pic), and seeing signs of water intrusion, thinking water got in here.
Next, thinking of disconnecting everything it controls and see if that makes a difference.
Controls: Pentair variable speed pump, 2 jandy valves, booster pump, hayward gas heater.
