I see you connected it, but how? Inside is soldered. I bought the antenna but how did you connect it?
I see that and bought an antenna that would work with that type of mount. But my unit appears to be hard wired. When I try to unscrew it, the entire unit, inside as well, turns. Q: If I lock the inside nut, would the outside unscrew? Does this look like that type of antenna?Welcome to TFP.
The antenna has a rp-SMA connector that unscrews at the the knurled ring.
SMA connector - Wikipedia
en.wikipedia.org
Post a pic of what you have.
Well, its about 3 or 4 years old. Had the hand held version before and upgraded to this one. Dang!!Yeah, your antenna looks different. I don’t know if you have an older model and Jandy changed the antenna used.
Thanks, Worth a try and ordered it. I had already bought this, but i guess it would work. https://smile.amazon.com/gp/product/B07R21LN5P/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1That looks like an antenna with a short cable pigtail attached to it. The connector on the end of the cable is called a U.FL (aka UMCC) connector. Here is an antenna that will probably work but it looks like it mounts a little differently to the box. The frequency range is right and it has the U.FL connector on the end.
W1049B050 PulseLarsen Antennas | RF/IF and RFID | DigiKey
Order today, ships today. W1049B050 – 2.4GHz Bluetooth, Wi-Fi, WLAN, Zigbee™ Whip, Tilt RF Antenna 2.4GHz ~ 2.5GHz 2dBi U.FL (UMCC), IPEX MHF1 Connector Mount from PulseLarsen Antennas. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.com
It's only $3.18 so it cheap enough to try.
Mark
With thanks to Marie from Fluidra, we have concluded that the antenna that attaches to thhis antenna box is not detachable and is soldered onto the box. I will need to replace the complete IQ20-A antenna box. I will inform my pool maintenance company. Meanwhile, does anyone have a lead for where I can purchase one if he has difficulty getting it? FYI, here's some more pictures.Gregg,
You may be able to make the one you have work. That cable that comes with your antenna is a U.FL to bulkhead mount R.SMA. You can probably remove the current antenna and then mount the bulkhead R.SMA in the hole where the antenna was. The nut on the SMA connector goes on the outside of the box and holds the connector in place. Then the antenna would just screw on like the ones on the current IAquaLinks. The U.FL end of the cable would connect to the pc board connector where the current cable goes.
Those U.FL’s are just press fit on, and something like a pair of curved tweezers will help you get old one off. You can also just grab it with your fingernails and pull it off the pc board if you can get your fingers in there.
Mark
