iAqualink 3.0 pump speed question
I have the PDA system and can turn features on and off with iAqualink on my iPhone.
I don’t think the PDA system allows the full features of the web interface? I think all the system setup and configuration needs to be done via the PDA where the RS system allows you to setup and configure every thing via the web interface.
The Status page provides also provides additional information when using VS pumps that’s not available on a PDA system.
So while you can use the web interface with the PDA systems it has a limited capability compared to the full RS system.
Those screens look correct.
A couple of thoughts, you might try clicking the button on the VSP Setup page that says "Restore Speed Defaults". I'm not sure what that will do, only reset the min and max speed ranges on that VSP Setup page, or if it will also restore the default speeds and Speed labels on the VSP Speed Setup page also?
So you are saying that when you click on any of the blank Speed Label rows you don't get a "General Labels" screen like @PoolGate showed in message #14?
What do the Speed Labels show for your Auxilary pump, and for that matter for Epump3 and Epump4 that are not installed. On my not installed pumps the Speed Labels all say Speed 1 through Speed 8 on the different rows.
If that "General Labels" screen isn't available to you something may be wrong with your system and if might be time to call Jandy customer support and have them log into your system to see if they can figure out what is going on?
Hey guys, I'm having the same exact issues as Joel, screens are the same, everything is the same except I only have 1 pump, did this ever get resolved?
Kind of, You have to upgrade to the RS system to get pump status to show on web interface.
Thanks Joel, I called Jandy and they told me it wouldn’t show up on the app since I have the PDA hooked up, I’m not sure I’m buying that, I asked him if I disconnected the PDA, could he fix it for me? Of course they said I needed a tech here to do it🤷‍♂️
