Moved from here.
I bought a Netgear WiFi range extender to hook up with my ORBI. Once I did this and hard wired the connection my system showed back on my iPhone. Then I disconnected and tried again on my Orbi vial iPhone and it recognized my WiFi.
My IQ20 is a few years old and I also just lost my WiFi connection for no reason. I tried numerous times to reestablish to no avail.Guys,
About a year ago upgraded my Jandy power Control center to Zodiac iAquaLink 2.0 Upgrade Kit for RS Systems | IQ20-RS that uses IQ20-A comms module.
Everything worked fine for about a year, but 3 days ago I lost WiFi connectivity. Went through troubleshooting steps, but Aqualink wifi SSID does not show up on any on my devices (iphone, laptops, etc). I did not change my router.
I switched to Ethernet cable mode and I got connectivity.
I even tried WPS method that my router supports - no luck.
Power cycling, double toggling wifi/ethernet switch - nothing works.
Talked to zodiac support, tried his procedure, and the person confirmed I am out of luck...
Anybody had similar issue and have been able to revive the wifi connection on the IQ20-A?
Is there a management IP/Port I can access on the device to see what's going on?
I will try replacing the PX/U.fl Pigtail rf connector with wifi antenna - see if that helps.
It is unfortunate to see that the comms module replacement cost $300, and only lasts a year or. Definitely not giving more $ for Zodiac.
Tomas
